Switching Odometer to Read in Kilometres??
Guest dreams95
Guest dreams95
I've got a Odometer that is currently in Miles and reading in Miles, is there anyway to make this odometer show its value in Kilometres and to also record in Kilometres?
I also Purchased a spare Odometer and performed the soldering resistors to different parts of the circuit board and i completely messed the odometer up it stopped working and turning on all together.
http://homepage.ntlworld.com/peter.betts/supra/TechTips/odometer.htm
That is the trick i used ^^.
So, that being said is there any other way to convert the odometer to kilometres, Other than the method i've already tried?
Guest dreams95
Hello mate,
Buy a jap odometer that is originally in kilometres. I have mine and works fine :)
Cheers
the car is a Left Hand Drive, the Jap Odometer does not work because i tried to find a way to mount it. Would of had to solder it off and solder it onto the left hand drive circuit board
