Bios upgrade on Aopen via dos?
Guest adi-mkiiisupra
Anyone know if you can do a bios flash via dos on an aopen motherboard ?? The aopen site sucks !! I've searched and i can find is the windows utility.. waste of time if you cant boot to windows..
Any help? Its an AK778XN...
When you flash a bios you normally do it in dos mode. At Steve said, you should be able to create a boot disk and then run the flash util from the a drive.
If you go to http://www.bootdisk.com/ you can get win95 boot disks, these are much faster loading and don't have loads of extra crap.
Create a boot disk, then copy the flash utils to the same disk. If you don't have space on the disk, just use another one and swop when the system has booted.
You're proabbaly aware, but, don't loose power when you're flashing the BIOS, it could leave the system shagged!
yes, but i cant run a windows executable from dos !! Thats my point.. the only utility to flash an aopen motherboard appears to be a windows based one... i cant find anywhere a dos flash application for the aopen board.
Ahh.. I see what your saying now!
It looks as though AOpen are doing away with DOS flash utilities and going for Windows based version instead.
If you look at this link
You should find this is the slightly older DOS version.
Not much use if you want to go to the latest version and can't get into Windows!
yep.. its a bit crap really.. just like the aopen site itelf :D for a biggish company their website sucks...
Anyway, thanks for the link.. now working.. must have missed it before :D
