binfieldx Posted June 24, 2015 Share Posted June 24, 2015 It looks as if maybe my insider rear arches have been cut away and re welded, I can see there's some kind of sealant over them and then they've been primer sprayed across in black (you can see the streak of black paint across the white in the picture below), does anyone know why they might have cut away at these inner arches? I'm assuming its to do with when they cut away and welded the wide body arches to the outside but can't understand why they would do the inside? It can't be to do with rust as there isn't a spot of rust anywhere on the car! Link to comment Share on other sites More sharing options...
cushti Posted June 25, 2015 Share Posted June 25, 2015 Guessing but could it be to fit a wider wheel/tyre combo inside the arch itself? Link to comment Share on other sites More sharing options...
binfieldx Posted June 25, 2015 Author Share Posted June 25, 2015 My thoughts exactly. The rears currently are 10.5j which is already pretty wide but I'll assume if the inside arches have also been widened maybe in the past it had much bigger wheels on it? Link to comment Share on other sites More sharing options...
cushti Posted June 25, 2015 Share Posted June 25, 2015 Maybe a drag car in a previous life, where's it from US, UK or Japan? They do it a lot in the US putting huge wheels inside slammed low riders with the wheels tucked up inside the arches Link to comment Share on other sites More sharing options...
binfieldx Posted June 25, 2015 Author Share Posted June 25, 2015 It's from japan built by a tuner company so quite potentially it sounds like it may have been setup for track as it's got race pads + race clutch + SARD attack meter Link to comment Share on other sites More sharing options...
