PLEASE HELP!! High Idle Problem
supersizejim
Ok the other week I went out for a blast. Car was spot on, gave her a dame good beating which was all fine. However upon slowing down, I noticed the revs staying highish 1500+rpm. When Ryan mapped it, he set the idle around 800-900rpm which Is spot on for her. However since that blast, its just idling too high for my liking. Does not matter if the car is cold or hot, its sitting too high! What is weird, is that if I'm sitting at a set of lights and I apply the brake and ride the clutch to push the revs down, it then drops to around a 1000.
Checked all the pipes/hoses..all seem fine etc.. Still boosting like an animal, so cant have any split hoses either. Took the idle control sensor out, cleaned it up and checked it, and put it back in. That seem fine also.
Other than doing a 'Data Log' and sending it to Ryan @2bartuning, I'm outta idea's??
I'm open to suggestions folks.. Please give any input guys. Probably something silly. :blink:
