Suprahitz Posted November 10, 2014 Share Posted November 10, 2014 (edited) Has anyone struggled with this plug? Whats best way to unplug ? Seems to be a pig after lots of fiddling and gentle force using tools but fear might damage plug: This is from a 1994 Jspec auto TT Edited November 11, 2014 by Suprahitz (see edit history) Link to comment Share on other sites More sharing options...
Mad Hatter Posted November 20, 2014 Share Posted November 20, 2014 I've just replaced my rad and this was a pain to get off, pinch the tab and tease it gentle off as you don't want to crack it. Old plugs are quite brittle. In the end I used a thin flat blade screwdriver to lift the tab which 'clicks' and it came off. Worst case, it's only two wires so you would replace both sides with a different mating plug. Link to comment Share on other sites More sharing options...
Suprahitz Posted November 21, 2014 Author Share Posted November 21, 2014 Thanks bud. Glad its not just me! I managed to release it eventually. Had to remove the IC pipe next to it running up the throttle body for more room. Link to comment Share on other sites More sharing options...
