Patrick_Devlin Posted March 11, 2003 Share Posted March 11, 2003 Guys, Ive posted something on the For Sale, Wanted section. I need a window motor. Mines just packed up. It's chewed the cable up and now the window is stuck down. Can I just replace the cable? Can I get the window up? Has anyone got one lying around? Are they unique to the Supra (can I fit another one?) Help would be gratefully appreciated. Link to comment Share on other sites More sharing options...
Alex Posted March 11, 2003 Share Posted March 11, 2003 I had this very recently too....must be the colour they must have put duff ones in! You haven't specified Drivers or passengers side. Brian Duff has a passenger one for sale. I had the drivers one off his scrapper! EDIT - you need the whole mechanism not just the motor and cable. Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted March 11, 2003 Author Share Posted March 11, 2003 Arse and double arse... Stupid MSB Supras. Its the drivers side one. Only got it serviced yesterday, sods law. Still, the HKS Hiper that was fitted sounds bloody awesome, even more so with the window stuck open!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Nathan Posted March 12, 2003 Share Posted March 12, 2003 I've got a drivers side one. It's all assembled ie motor/cables/metal slider bar etc..... How much are they new then.. Nathan TDI PLC Link to comment Share on other sites More sharing options...
Roy Posted March 12, 2003 Share Posted March 12, 2003 nathan - if you find out what the price is, pls let me know as well as i think mine is beginning to pack up also. there is a funny rattling sound everytime i either raise or lower the driver's side window. thanks. Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted March 12, 2003 Author Share Posted March 12, 2003 Originally posted by Nathan I've got a drivers side one. It's all assembled ie motor/cables/metal slider bar etc..... How much are they new then.. Nathan TDI PLC Nathan I've emailed you... Pat Link to comment Share on other sites More sharing options...
Matt Harwood Posted March 12, 2003 Share Posted March 12, 2003 Patrick, was your window making any strange noises before it died? I'm just wondering if it's something that could be avoided if it can be cleaned/lubricated. Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted March 12, 2003 Author Share Posted March 12, 2003 I dont think so Matt. I'm not sure if the cable jumped the pulley or not. I havent checked that. Maybe the pulley broke. Regardless, I still need the new motor, and now I'll have to check the pulley Link to comment Share on other sites More sharing options...
Alex Posted March 12, 2003 Share Posted March 12, 2003 A single strand of wire frayed on mine at the joining block on the mechanism....over a no. of months it tore up the pulley...the noise was like a crackling sound. Should have taken a look earlier but I didn't. There isn't much room inside the motor/pulley area and so if the cable goes, inside that area, then it could jam it straight away... Link to comment Share on other sites More sharing options...
MONKEYmark Posted March 12, 2003 Share Posted March 12, 2003 my drivers side cable was making noises then stopped working, stripped it down and cable had snapped thought you might be able to buy new cable but its an all in one unit cost me £70 dont know if it was including or excluding i asked them how much to fit it, they wanted £92 as it was stripped i fitted it myself easy job to do and i am crap just take your time doing it have fun Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted March 16, 2003 Author Share Posted March 16, 2003 All fixed now, Thanks to Nathan at TDi for sorting me out a 2nd hand part. 24 hour delivery and a couple of hours to fit it and I 've got a working window. The top pulley had broken and the cable had tangled in the motor as a result. Bit of a bitch to remove the old one cos the window was stuck down. Got the old one if anyone wants to recondition it? Pat Link to comment Share on other sites More sharing options...
MONKEYmark Posted March 17, 2003 Share Posted March 17, 2003 how much was it then? is an all in one unit so cant see it been of use to anyone. its a pretty easy job when you see how it works. took my glass out when i did mine and gave it a good clean. Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 17, 2003 Share Posted March 17, 2003 Not sure if this is the same part as you guys ended up buying, but may help others who come across this thread in future. http://www.supraforums.com/showthread.php?s=&threadid=110390 Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted March 17, 2003 Author Share Posted March 17, 2003 I got the whole fixture for £130. It included the motor, guide rail and window mount; the whole shooting match. I havent taken the motor apart yet, but may do. The cable is frayed and I guess it could be mashed up inside the casing. The top runner (plastic) has broken also - the initial problem I think. Pat Link to comment Share on other sites More sharing options...
Alex Posted March 17, 2003 Share Posted March 17, 2003 The motor will be fine if a little tired! Its the big pulley which will have lots of sharpe debris from the cable littering the inside. If you do open up the big pulley take care...I was picking fine bits of wire out of my fingers for the rest of the day. Link to comment Share on other sites More sharing options...
MONKEYmark Posted March 17, 2003 Share Posted March 17, 2003 Originally posted by Patrick_Devlin I got the whole fixture for £130. It included the motor, guide rail and window mount; the whole shooting match. I havent taken the motor apart yet, but may do. The cable is frayed and I guess it could be mashed up inside the casing. The top runner (plastic) has broken also - the initial problem I think. Pat £130 was that new? when i did mine new part was £70about remember because toyota wanted more to fit it than the part was worth its the cable in the round plastic plug that pulls both ways and has a slider bar . i thought it might have been more knowing toyota Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted March 17, 2003 Author Share Posted March 17, 2003 Originally posted by MONKEYmark £130 was that new? when i did mine new part was £70about remember because toyota wanted more to fit it than the part was worth its the cable in the round plastic plug that pulls both ways and has a slider bar . i thought it might have been more knowing toyota Here is a picture of the entire assembly. This is what Toyota wanted to charge me £250 for... It was the pulley on the left hand side behind the window bracket that broke. Link to comment Share on other sites More sharing options...
MONKEYmark Posted March 17, 2003 Share Posted March 17, 2003 same thing i bought for £70+ how can the prices be so much different Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted March 18, 2003 Author Share Posted March 18, 2003 Must be the North South divide again... Rip off Britain... etc... Dont know mate, all I know is that it was half the new price Link to comment Share on other sites More sharing options...
