Slutters Posted March 16, 2013 Share Posted March 16, 2013 Hi guys Fitted my Spec 2 Plate clutch a while back but just managed to try it today. The clutch will not fully disengage. There is not enough fluid provided by the master cylinder, i have tried adjusting the pedal but had no joy. I was aware of this as a possible issue and was sent a Tilton Master Cylinder with the clutch, it uses a 19mm bore instead of the OEM's 15mm. However it is a universal item. I am missing the adapter that converts the Tilton to the Supra bolt patten. Has anyone got one? Or know where to get one? The only place so far is from the USA. Any help would be great! Link to comment Share on other sites More sharing options...
Steve Posted March 16, 2013 Share Posted March 16, 2013 The only place I know of is Twins Turbo USA. Link to comment Share on other sites More sharing options...
