Cusco top mount bearings
antno
Anyone know where I can get some cusco top mount bearings from?
I've tried co-ordosport/part box, tried local bearing traders and had a friends searching through most Motorsport bearing suppliers but I can't find them. The closest thing is the same as the tein one which is 2mm smaller on the od.
The size I'm after is 35 od. 18 id. 16mm thick. Think the ball height was 20mm.
I would be happy if I could get all but the I'd the same then just machine some new sleeves to fit in the middle
Cheers antno
  • 3 months later...
Found this in the end direct from cusco Japan £60 each and 4-6 week lead time. I've tried all the big bearing traders and they couldn't supply one.
If any one needs one co-ordosport are the people to talk to
Cheers
