How many litres of coolant?
Toms Supra
One bottle of Water Wetter should be enough.
Don't expect miracles from it, most of the difference comes from running fresher coolant and a weaker mixture perhaps (I run 80% water in the summer, 60% water in the winter)
Yeah there should be some level marks on the tank. Fill up the rad, get all the air out of the system. I just kept squeezing the bottom pipe and the heater pipes to force the air out (with engine running and heater on full). When cold top up the expansion tank and go driving. Just keep your eye on the tank for a while as it may draw more water from it if there is some air still trapped in the system.
