Guest tony1979 Posted October 2, 2011 Share Posted October 2, 2011 Evening all, Just a question about my fog lights, the rears are working fine, but the front are not, ive changed the bulbs, but no joy, theres only one switch for the fogs, i am i missing something. 1995 import????. Link to comment Share on other sites More sharing options...
damadom Posted October 2, 2011 Share Posted October 2, 2011 erm did you know that the front fogs are on the right stick with the rest of the lights? Link to comment Share on other sites More sharing options...
nevins Posted October 2, 2011 Share Posted October 2, 2011 fogs are in the headlights mate, but if you have changed the bulbs you know that. Also check the fuse, its driverside in the kick panel. Link to comment Share on other sites More sharing options...
Guest stevie.84 Posted October 2, 2011 Share Posted October 2, 2011 Yeah I agree on the fuse - try checking the fuse in the engine bay - it's number 6 and should be a 15A fuse Link to comment Share on other sites More sharing options...
Guest tony1979 Posted October 2, 2011 Share Posted October 2, 2011 I am getting confused here, right hand stick, side lights, main beam, full beam, are the front fogs on there as well , i have a separate switch for the rear fogs on the dash, i thought they would have controlled the fronts as well, or i am being dull. Link to comment Share on other sites More sharing options...
nevins Posted October 2, 2011 Share Posted October 2, 2011 twist the stalk closer to the wheel Link to comment Share on other sites More sharing options...
Guest stevie.84 Posted October 2, 2011 Share Posted October 2, 2011 4 bulbs in a headlamp bud, main beam, dipped beam, foglight at the end and a little side light in between dipped and fog - will look like a little bubble if that helps Link to comment Share on other sites More sharing options...
