spiderpigcity Posted August 10, 2011 Share Posted August 10, 2011 where is the best place to fit a fuel pressure sensor on boostlogic fuel system? Link to comment Share on other sites More sharing options...
bignum Posted August 10, 2011 Share Posted August 10, 2011 Has the fpr got ports on the side, my aeromotive has. Link to comment Share on other sites More sharing options...
spiderpigcity Posted August 10, 2011 Author Share Posted August 10, 2011 my aeromotive is using all 3 ports as i have 2 lines in, and 1 return. but i was wondering if i could unscrew the gauge and use that port for a sensor? if so what fitting would i need? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted August 12, 2011 Share Posted August 12, 2011 my aeromotive is using all 3 ports as i have 2 lines in, and 1 return. but i was wondering if i could unscrew the gauge and use that port for a sensor? if so what fitting would i need? Yes you can, it's 1/8 npt, most pressure sensors will be this thread so it should screw straight in. Link to comment Share on other sites More sharing options...
