k9l3 Posted July 23, 2011 Share Posted July 23, 2011 can someone please tell me how easy is it to change rear speakers . I know you need 6.5' speaker. Is there any soldering required or is it just connectors . also how do people get the glue of the screwss any tips. thanks Link to comment Share on other sites More sharing options...
marbleapple Posted July 23, 2011 Share Posted July 23, 2011 If you looked at the most noob of noobs in the car technical world you would find me.... And I did it. Just prise off the cover and use your common sense. It is self evident. Honestly. No cutting wires or anything like that. Just screw out and screw in. Link to comment Share on other sites More sharing options...
k9l3 Posted July 23, 2011 Author Share Posted July 23, 2011 If you looked at the most noob of noobs in the car technical world you would find me.... And I did it. Just prise off the cover and use your common sense. It is self evident. Honestly. No cutting wires or anything like that. Just screw out and screw in. thanks mate that's great I will have a go later thanks. Link to comment Share on other sites More sharing options...
Irish_Al Posted July 23, 2011 Share Posted July 23, 2011 Done it myself two weeks ago and its the easiest thing you can do. Only thing you might need to do is pry the speaker away from the bracket as mine was glued on as well as screwed on. Other than that its easy as pie (disclaimer - I can't be held responsible if car explodes) :) Link to comment Share on other sites More sharing options...
Suprab1 Posted July 23, 2011 Share Posted July 23, 2011 I found it an absolute nightmare getting in & out the back seats of the supra apart from that it is easy peasy. Link to comment Share on other sites More sharing options...
