The Hornet Posted July 7, 2005 Share Posted July 7, 2005 Just took her in for MOT and it failed only on emissions. Thought I would just stick it in to see what they said - hehe Results: Fast idle speed - CO = Second Fast idle - CO = \some other symbol - 0.970 - 1.030 - mine = 1.040 = Fail All the other lines on the sheet was either a pass or not checked... Have to take me 2 CATS in on Monday for them to re-fit & re-test Are the above about what mine should be reading at BPU+ ? Hornet Link to comment Share on other sites More sharing options...
Class One Posted July 7, 2005 Share Posted July 7, 2005 You should be able to pass with just the second cat installed. Link to comment Share on other sites More sharing options...
The Hornet Posted July 7, 2005 Author Share Posted July 7, 2005 Will tell them to just re-fit that one first then to save on a bit of labour What about if I stick the Baffle in the end of me NUR Spec R as well ? Link to comment Share on other sites More sharing options...
eyefi Posted July 7, 2005 Share Posted July 7, 2005 what where the HC readings? baffle won't do anything for emissions. Link to comment Share on other sites More sharing options...
The Hornet Posted July 7, 2005 Author Share Posted July 7, 2005 HC readings: Fast Idle test - HC = Second fast Idle test - HC = I dont know what all that means just what it says on the sheet Link to comment Share on other sites More sharing options...
eyefi Posted July 7, 2005 Share Posted July 7, 2005 cheers dude, thats great info, thanks Link to comment Share on other sites More sharing options...
The Hornet Posted July 7, 2005 Author Share Posted July 7, 2005 Oh OK, thought you was gonna tell me something or gimme some info that might be useful or something No probs though - hehe Link to comment Share on other sites More sharing options...
Markie Posted July 7, 2005 Share Posted July 7, 2005 Good readings for the girl without any cats in mate. All looks fine and will fly through I would of thought with just 1 cat in. I have heard sticking the silencer in the back does help, as reading can get a bit in-accurate with just a big tail pipe. The "symbol" is the LAMBDA sensor readings. Again, does not look too bad. Link to comment Share on other sites More sharing options...
The Hornet Posted July 7, 2005 Author Share Posted July 7, 2005 Cheers Markie, didnt know what it was and the keyboard didnt have that symbol Link to comment Share on other sites More sharing options...
eyefi Posted July 7, 2005 Share Posted July 7, 2005 i was using you for my own ends see here you could try running a bit leaner if you have a fuel computer Link to comment Share on other sites More sharing options...
The Hornet Posted July 7, 2005 Author Share Posted July 7, 2005 Nope SAFC as yet, just waiting for turbo's to blow, then its bigger injectors, SAFC, and a T60/ T61 for me Just read you other post, I guess my results helped then, and she is running on 97RON BP Ultimate at the time too (as 98ron shell is rare around here). Link to comment Share on other sites More sharing options...
