aristo mk2 2jz-gte vvti fan not cutting in :(
Guest mrrobnorcross
Guest mrrobnorcross
hi guys, i have a vvti twin turbo 2jz in my mark 2 aristo, in the past few days the main ran the cool the engine is not coming on! [sAD][/sAD]
is there anything in particular that is common to let go on the toyota fans at all?
all the fuses have been checked, the gauge is showing its overheating.
any help would be great! thanks
Edited by mrrobnorcross (see edit history)
Guest mrrobnorcross
ah ok yeah will do, thanks
umm alarm is a cat 1 clifford thats been on since ive had it, so i have no idea to be honest! :(
what does the efi fuse control? sorry if thats abit of a noob question
Guest mrrobnorcross
ahhh right ok cool :) should they come on strait away? or when the engine has warmed up??? shall i turn it on with the fuse disconnected?
  • 1 month later...
Guest topdog849
get some electric fans, I hear the ford tourus fans flow a lot of cfm and can be found at junkyards cheap
