Guest mrrobnorcross Posted March 29, 2011 Share Posted March 29, 2011 (edited) hi guys, i have a vvti twin turbo 2jz in my mark 2 aristo, in the past few days the main ran the cool the engine is not coming on! [sAD][/sAD] is there anything in particular that is common to let go on the toyota fans at all? all the fuses have been checked, the gauge is showing its overheating. any help would be great! thanks Edited March 29, 2011 by mrrobnorcross (see edit history) Link to comment Share on other sites More sharing options...
Guest mrrobnorcross Posted March 29, 2011 Share Posted March 29, 2011 oh forgot to say heater is fully working blowing hot air Link to comment Share on other sites More sharing options...
michel lane Posted March 29, 2011 Share Posted March 29, 2011 how is your alarm hooked up ? is it getting the feed from the fan circuit ? Link to comment Share on other sites More sharing options...
Awisto Posted March 30, 2011 Share Posted March 30, 2011 Pull the efi fuse with the ignition turned on and report back Link to comment Share on other sites More sharing options...
Guest mrrobnorcross Posted March 30, 2011 Share Posted March 30, 2011 ah ok yeah will do, thanks umm alarm is a cat 1 clifford thats been on since ive had it, so i have no idea to be honest! what does the efi fuse control? sorry if thats abit of a noob question Link to comment Share on other sites More sharing options...
Awisto Posted March 30, 2011 Share Posted March 30, 2011 When the efi fuse is pulled, the fans should come on, if they do, you'll know it's not a complete power failure to them, and you'll be a little step closer. Link to comment Share on other sites More sharing options...
Guest mrrobnorcross Posted March 30, 2011 Share Posted March 30, 2011 ahhh right ok cool should they come on strait away? or when the engine has warmed up??? shall i turn it on with the fuse disconnected? Link to comment Share on other sites More sharing options...
dangerous brain Posted March 30, 2011 Share Posted March 30, 2011 Car won't start with the efi electronic fuel ignition fuse pulled as it needs ignition to run mate Link to comment Share on other sites More sharing options...
Guest mrrobnorcross Posted March 30, 2011 Share Posted March 30, 2011 oh right kk, how long do you need to pull it for before you put it back in? Link to comment Share on other sites More sharing options...
Awisto Posted March 30, 2011 Share Posted March 30, 2011 Pull the fuse, turn the ignition on, fans should come on straight away if there's not a power problem. Link to comment Share on other sites More sharing options...
Guest mrrobnorcross Posted March 30, 2011 Share Posted March 30, 2011 even if the engine is cold???? Link to comment Share on other sites More sharing options...
Awisto Posted March 30, 2011 Share Posted March 30, 2011 Yes, it's a safety precaution I believe. This won't fix your problem, it's just going to tell you if there is a complete lack of power to the fans. Link to comment Share on other sites More sharing options...
Guest topdog849 Posted May 14, 2011 Share Posted May 14, 2011 get some electric fans, I hear the ford tourus fans flow a lot of cfm and can be found at junkyards cheap Link to comment Share on other sites More sharing options...
