Soarer suspension
seba
To make a long story short, my supra is going to the garage next week blablabla blabliblu
Do the Soarer arms, wishbones, wheel hub etc all fit the Supra? Have damage on the car and someone offered to give(sell) these from a Soarer. I still don't know whats actually wrong because i can't get a good look at it and the wheel is so bend that i can't even take it of.
Thx
Edited by seba (see edit history)
Depending on the year almost all are the same. The front is the rear has a different subframe and arb mount. If you want to use the Soarer stuff you will need to use the Soarer rear subframe. Basically the subframe on a Sup hangs out wider meaning the lenght of the arms is shorter, on a Soarer they are longer with a less wide subframe. The frames themselves are totally swapable, you just need to change the hand break cables.
Edited by Andy-No-Knee (see edit history)
So i can use any part from the front without problems? I think the rear only needs the hub replaced but not sure. But the rearparts can never fit the Supra without swapping the entire Soarer subframe? If this is correct i'd better have a look out for some replacementparts if needed, don't want any unnecesary costs.
