My Spark Plugs
terribleturner
Changed my plugs yesterday. A little P O'd coz the recipt from the last bloke who owned the car said it had IK27's in, but when i got them out they were 24's. Do you think the state of them would be the cause of my hesitation and revs bouncing at 90/100 in Top gear?? because i've put 27's in instead of 24's it's not gonna be a straight swop where i can compare results. :(
Guest Terry S
I would personally go to a warmer plug than a 27 for your application James. The 24's would be fine, but depends how long they have been in there.
Guest chiefvinso
Excuse me for jumping into a conversation, but which plug is the colder? 27 right? When you say foul up, does that mean burn out or coke up or whatever. Cheers
Guest chiefvinso
I thought a colder plug would be good for higher boost or probably does it have relation to air intake temp which plug you should use?
Guest Terry S
you are correct. For the really big power cars , but my poor car is running just fine on NGKBCPR7ES' which are the grade equivalent of an IK22 ;)
Colder plug = wont pre-detonate/ignite due to the heat in the cylinders, therefore less chance of det.
More boost = more heat in cylinders.
Hence the more boost and power your running, the cooler the plug you should use.
But go too cool and you will have spark problems
Guest chiefvinso
Hmmmm, interesting - when I get my car it will be serviced and pressumably the plugs will be manufacturers recommendations. Will these be ok for the time being or should I get some iridium plugs to be safe?
The car is almost standard, it has an HKS drager zorst and some hks air intakes but the rest is standard - except for boost gauge. Cheers
Your probably running close to standard boost, so standard plugs will be fine. Nothing wrong with going a grade cooler though if you plan to uprate anything else at some point. I *think* iridium plugs offer no performance upgrade other than lasting longer
Guest chiefvinso
And leave the leads standard? One of the first mods recommended to me by a jap car tuning business for my mr2 turbo was some iridium plugs and magnecor leads just to start me off.
Guest chiefvinso
Terry its a TT, should have said that in the beginning. Taking over terribleturner's thread - sorry!
Guest Terry S
Terry roughly what sort of price are they?? Gonna get some 24's from the US for about £40/45.
What the NGK's, about £1.50 a plug
