XS power manifold 2JZ-GTE
mrgee2jz
Up for grabs is my xs power manifold from my 6 speed 2JZ-GTE
I had a GT4094R runing low boost of 1.5bar (boost pipes kept comming off) @ 741hp with this manifold and no problems
It eventually cracked as it wasnt supported, its been welded now and should be even stronger than before. Ive now changed to a greddy manifold now to run around 900hp so no longer need this.
Wastegate is now top mount but ive removed the flange to use on my new setup, but i have a greddy 4 bolt flange that can be included or even welded on for the new buyer
£70
