Jurgen-Jm-Imports Posted November 9, 2010 Share Posted November 9, 2010 anybody some data or instructions they can share,need the colour of springs and what boost they run ? thanks Link to comment Share on other sites More sharing options...
Miguel Posted November 9, 2010 Share Posted November 9, 2010 (edited) IIRC the 60mm GTII is as follows: Large spring on its own: 0.6~1.0 bar + the next size down: 0.9~1.3 bar + next size down: 1.3~1.7 bar + next size down ( all of them fitted): 1.7~2.1bar. I'm sure one of the HKS traders will be able to confirm if that's correct or not. Edited November 9, 2010 by Miguel Numeral amendment. (see edit history) Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 9, 2010 Author Share Posted November 9, 2010 IIRC the 60mm GTII is as follows: Large spring on its own: 0.6~1.0 bar + the next size down: 0.9~1.3 bar + next size down: 1.3~1.4 bar + next size down ( all of them fitted): 1.7~2.1bar. I'm sure one of the HKS traders will be able to confirm if that's correct or not. thangs mig, hopefully one of the traders or forum member can help with colour etc Link to comment Share on other sites More sharing options...
Miguel Posted November 9, 2010 Share Posted November 9, 2010 (edited) I'm not sure the GTII springs have a colour system? Can't remember. They are all physically different in size anyway, you just add or subtract the amount of springs in the gate to achieve the base pressure you want. Edited November 9, 2010 by Miguel (see edit history) Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 9, 2010 Author Share Posted November 9, 2010 I'm not sure the GTII springs have a colour system? Can't remember. They are all physically different in size anyway, you just add or subtract the amount of springs in the gate to achieve the base pressure you want. i recall reading it and it said something about colours. Link to comment Share on other sites More sharing options...
Miguel Posted November 9, 2010 Share Posted November 9, 2010 Have a look at the springs mate, they fit inside each other. It's real easy to work out. All four springs in the gate will be 1.7~2.1 base; just the largest diameter spring on its own will be 0.6~1.0 bar. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 9, 2010 Author Share Posted November 9, 2010 ok cheers mate i will work it out.. Link to comment Share on other sites More sharing options...
