Guest Terry S Posted August 24, 2005 Share Posted August 24, 2005 The turbos only need a bit of oil for lubrication, they have tiny bearings, look at the oil feed size to a crank main bearing, they are only about 1/8 inch bore. The turbo needs a good deal of flow at low pressure, to remove heat. No need for big pressure pipes, but the drain needs to be TOTALLY unrestrictive, hence the BIG drain size. Which is exactly what comes in the kits Link to comment Share on other sites More sharing options...
eyefi Posted August 24, 2005 Author Share Posted August 24, 2005 the restrictor in the gtbb's oil intake is a 0.035" hole size Link to comment Share on other sites More sharing options...
