turbo timer
BRIAN.M
hi i am fitting a greddy full auto turbo timer to my 93 j-spec auto tt
there is a speedo/auto timer feature which it says connect to the speed signal wire on the ecu, is this the best place to conect it or am i better off picking it up at the back of the speedo head? either way could someone please tell me the colour of the speed signal wire or the ecu pin. :shrug: :thanks:
brian
as you pull out the gauge cluster and tilt it down, the left connector (think its blue) you want the blue/red wire, which is the 5th one along from the left... or on the ECU the right connector and you want the pink wire which is the 2nd from the right on the top row, very easy to get too...
dont think it matters which one to connect it on to really...
