Aem uego
Stephendjb
I'm changing over to the PLX DM-100 to reduce the number of gauges I'm going to need to keep an eye on the semi-experimental set up we're running.
Digital Wideband Air / Fuel Gauge
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
Does not oscillate AFR reading like narrow band sensors
No laptop required for monitoring!
Bosch sensor included
Accurate to 0.1 AFR
Reads in AFR or Lambda via a switch in back of gauge housing
24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
Integrated three-digit display reveals AFR or Lambda in real time
User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
Serial data stream included for output of AFR (RS 232)
The gauge has been test fitted & nothing more, still complete with box instructions & unused bosch sensor probe
Just the AEM UEGO AFR gauge up for sale. NOT the Tru boost sorry.
£160 + delivery
  • 2 weeks later...
For £150! You did well! [sHOCK][/sHOCK]
Really?? You can find many places where you can get a brand new and in the UK AEM Eugo Controller for £150 delivered can you?
Cheapest I've found is about £20 more than that. Be interested to see some links.
these were going on ebay for 150 inc free delivery about a couple of months back.
All well and good a couple of months back, but in today's market the cheapest I can find is £174.95 + delivery.
Currency exchange rates and the like affect current prices eh. Link me one now for £150 delivered and I'll change my mind on this being a good deal.
