mikeyh Posted May 26, 2010 Share Posted May 26, 2010 does anybody have a guide on how to change the crank sensor any help will be a great[GRIN][/GRIN] Link to comment Share on other sites More sharing options...
GreaseMonkey Posted May 26, 2010 Share Posted May 26, 2010 (edited) I'm going to assume it's a 2JZ-GTE Engine, so hope this helps Pages IG-11 & IG-12, for removing the Crank Position Sensor. As per Toyota Engine Manual, in the link below. http://www.turbosupras.com/pdfs/JZA80%20TSRM/IG%20(2JZ-GTE).pdf The Resistance of the Crankshaft Position Sensor as per the manual as follows: also Ref: Page IG-1 in the above link Cold: 835 - 1,400 Ohms (ND) 985 - 1,600 Ohms (Aisan) Hot: 1,060 - 1,645 Ohms (ND) 1,265 - 1,890 Ohms (Aisan) "Cold" -10°C (14°F) to 50°C (122°F) "Hot" 50°C (122°F) to 100°C (212°F) (Sorry, couldn't do the dots for Degrees on the above) Edited May 26, 2010 by GreaseMonkey Ammended temps with SteveC tip on how to do ° (degrees dots) (see edit history) Link to comment Share on other sites More sharing options...
hodge Posted May 26, 2010 Share Posted May 26, 2010 Disconnect battery remove aux belt remove bolt from top of alternator remove undertray remove nut from bottom of alternator slide alternator out the way. Use a 10mm long reach 1/4 inch socket with a long extension to undo crank sensor bolt wiggle abd gently pull sensor until it comes free from behind timing belt tensioners repeat to refit. Hope this helps. Link to comment Share on other sites More sharing options...
SteveC Posted May 26, 2010 Share Posted May 26, 2010 (Sorry, couldn't do the dots for Degrees on the above) Alt + 0176 on the number keypad will give you a degree sign: ° Link to comment Share on other sites More sharing options...
GreaseMonkey Posted May 26, 2010 Share Posted May 26, 2010 (edited) :)Ahh, Cheers SteveC you star!. I've Learned more computer tips 'n shortcuts from being on this forum than I have anywhere else, lol!. Edited May 26, 2010 by GreaseMonkey (see edit history) Link to comment Share on other sites More sharing options...
SteveC Posted May 26, 2010 Share Posted May 26, 2010 You're welcome. Here's a few more 'Alt' codes you may find useful. Link to comment Share on other sites More sharing options...
GreaseMonkey Posted May 26, 2010 Share Posted May 26, 2010 You're welcome. Here's a few more 'Alt' codes you may find useful. Cheers SteveC Link to comment Share on other sites More sharing options...
mikeyh Posted May 26, 2010 Author Share Posted May 26, 2010 cheers guys ill have to have a look tomorrow Link to comment Share on other sites More sharing options...
