dude Posted March 3, 2010 Share Posted March 3, 2010 As its F-Con it can only be tuned by an Authorised HKS power writer, I can't even get in my F-Con without Matts laptop:search: Link to comment Share on other sites More sharing options...
Krister Posted March 3, 2010 Share Posted March 3, 2010 (edited) The idle is rich at 11-12,2:1 AFR, but it might be because of the 280 cams and 1000cc injectors, big lopy cams usually require a tad more rich mixture to idle correctly, but not that much. 14,7:1 is the stock idle and usually what people target at, but with my AEM EMS and 850cc injectors, 13.5-14:1 is the leanest I can go or it will idle like crap. In cruising it should be possible to get a 14,7:1 mixture and that is what you should target for, or even slightly leaner if you want to save some fuel as best fuel economy is at ~16:1 AFR. 14,7:1 is just a stoichiometer mixture that the catalytic converters need to work correctly, but who uses those anyway If you are at 10-11 AFR at WOT, and the car doesnt break up, I wouldnt worry about it that much. You will gain some power if you would tune it to around 11,5:1 AFR and it's overall better for the plugs. But you wont fuck up your engine if you keep driving it, that's just a retarded comment, but it's overall better if you get it tuned as it seems like the AFR's could be better. As a quick help, if you have a fuel pressure regulator with a gauge, you can try to lower the fuel pressure just a tad and see how the idle AFR's react. After that you need to and do a full throttle pass to see that your WOT AFR's are still within spec (under 12:1). Edited March 3, 2010 by Krister (see edit history) Link to comment Share on other sites More sharing options...
bodilx6 Posted March 8, 2010 Share Posted March 8, 2010 Any reason you are not taking contact to Lars from LKsport? He is the man for HKS tuning Link to comment Share on other sites More sharing options...
