Horn not working
Amir khan
Hello,
am having some problems with my horn, after changing my steering wheel the horn was working fine, I cant figure out why its not working.
The fuses are fine, but I cant figure out how i can check if there is a break in the circuit,
Should I be getting a 12v current through the centre of the steering column and the outside is ground?
If someone has any wiring diagram for the horn to help me isolate the problem or any advice that would be great thanks!
The horn circuit works by switching the negative so you won`t see any voltage. Try connecting the two wires together, if this works your horn push button is faulty. Make sure one of the horn push button connections goes to a good grounding point on the steering wheel boss. You could also connect the negative side of the horn to the chassis to make sure it is working;)
You don't need a horn mate. That massive set of jingly keys will tell everyone you're coming :D
Iv started to expect this now, message to fellow members, make sure your pictures have as little about you as possible as it WILL be used as ammunition against you :p
you gotta love this place :D
Iv got same problem. However mine was caused by replacing my a/bag steering wheel and boss with a momo wheel and non airbag boss.
Did yours have an air bag before? If so u may have the wrong boss in which case u need the 'plunger' thing that operates the horn.
  • 3 weeks later...
my horn is messed up also the car has a mono steering wheel fitted and its not working :( ps it was not working when i got the car on tuesday :(:(
