N/a to 2jzgte engine swap
luisito-awo
I'm planning to swap my supra n/a engine with an atisto 2jzgte twin turbo engine now my question is can the 5spd w58 gearbox handle the 2jzgte power? And what about the ecu and wire harness and do i need to look for an 2jzgte supra ecu harness? Or can I use the n/a supra ecu and harness ??
The gearbox can handle stock TT power and maybe slightly more but you will need TT engine loom, power steering resevoir, and Radiator fan and shrould if i remember correctly.
Plenty of threads on here about it.
http://www.mkivsupra.net/vbb/showthread.php?t=136136
http://www.mkivsupra.net/vbb/showthread.php?t=176732
Edited by ilicos (see edit history)
Now can I use the power steering , radiator , engine loom and ecu & harness ect ect from the aristo ? Or must it be from a tt supra
