Digsy Posted April 26, 2005 Share Posted April 26, 2005 Just wondering if anyone knew of anything like the below. I've tried searching on Maplin et al but with no sucess. Basically I'm looking for some kind of socket for a standard 5mm LED with 0.1" pin spacing. Something I could either mount on a PCB or solder to a pair of flying leads that I could then simply plug a standard LED into. I was thinking that some kind of PCB header strip might do the job, but the holes are too large to grip the LED pins. Link to comment Share on other sites More sharing options...
V Posted April 27, 2005 Share Posted April 27, 2005 er, if you could sketch something up so i can get a picture, i'll have a look around. Cheers Link to comment Share on other sites More sharing options...
Digsy Posted April 27, 2005 Author Share Posted April 27, 2005 I guess something like this would pretty much do the job. I found them not long after I posted yesterday. There's a UK supplier for them, too, but I think they might be a bit too bulky. I'll get some prices anyhow. A cheaper solution might be the way this guy has done it (except I'd do a much neater job ). I just need to look round Maplins to see if they have any suitable connectors. Link to comment Share on other sites More sharing options...
V Posted April 27, 2005 Share Posted April 27, 2005 (in to your fairy lights are you? ) OK, try here: http://cpc.farnell.com/jsp/endecaSearch/searchPage2.jsp?Ntt=led&Nty=1&N=411&Ntk=gensearch My mate works for SLI so should be able to get anything for minature bulbs. If theres anything that takes your fancy give me a shout & i'll see i can do, theyre not going to be £much, but i should be able to get them foc for you Regards SV Link to comment Share on other sites More sharing options...
V Posted April 27, 2005 Share Posted April 27, 2005 http://cpc.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=SC00200&N=411 ? Link to comment Share on other sites More sharing options...
Digsy Posted April 27, 2005 Author Share Posted April 27, 2005 Cheers dude. I'll let you know Link to comment Share on other sites More sharing options...
