Hks ssqv
ray007
maybe, how does it sound like, also i havnt got the adapter for the SSQV for a TT.
the sound of the blitz is nice, fairly loud but not over the top - it has a spare trumpet to change the noise of it too.
i just prefer the high pitch sound of the ssqv mate ;)
thats ryt, I have the t-flangle to go in-between intercooler pipes, i origionally bought it after buying the HKS SSQV on its own, wich i was going to install on an na-single turbo conversion. however i ended up buying an na-tt so never did the conversion and hence ended up with the wrong flange/adapter.
if you dont mind me asking, how much is it worth brand new?? and would you be giving the adapter with it?
just under $300 going by this site mate - http://www.driftnamiperformance.com/Blitz_DD_BOV_Supra_93_98_p/sdt-70044.htm
not sure what u mean about this flange though - i just want to be able to take mine off and fit an ssqv...is this not poss with what u have mate?
no unfortunately, you will need to buy the right flange/adapter to use the HKS ssqv
is it the pipe running down on the right past the battery ?
sorry for the confusion. i have a t-pipe which is around 7inches long which ideally should be mounted in-between the intercooler pipes, not ideal for a TT to be honest
have u got a link for that mate? if its easy enough i'd still be interested....
i havnt mate, ill have a look around, i think whifbitz said they have a flange but it wouldn't go straight on, you'll need to play around a bit
