Supra-Brett Posted August 5, 2009 Share Posted August 5, 2009 Ok, i have a replacement one for my old knackered one which the garaged diagnosed when it was in for a service. For once i might have a go at fitting something myself - it cant be that hard after looking at the pump itself ?. For starters i need to know where it is located I think its in the passenger side front wing type area. Can anyone advise 1) where its located 2) What tools i need to complete thee job 3) How hard the job is for a reletive novice 4) Provide a "how to" guide Thanks Link to comment Share on other sites More sharing options...
Scott Posted August 5, 2009 Share Posted August 5, 2009 Remove wheel Remove Arch Lining Remove bolts holding on washer tank Empty tank Replace Pump Reverse Job done, looks like a piece of piss once you get in there bud. Couple of plugs and pipes etc. Link to comment Share on other sites More sharing options...
Supra-Brett Posted August 5, 2009 Author Share Posted August 5, 2009 Remove wheel Remove Arch Lining Remove bolts holding on washer tank Empty tank Replace Pump Reverse Job done, looks like a piece of piss once you get in there bud. Couple of plugs and pipes etc. Wow sounds easy, is the pump attatched via any screws ? it doesnt seem to have any holes for attachment other than the hose`s ? Link to comment Share on other sites More sharing options...
Scott Posted August 5, 2009 Share Posted August 5, 2009 Wow sounds easy, is the pump attatched via any screws ? it doesnt seem to have any holes for attachment other than the hose`s ? I can't remember specifically but i don't remember anything. I didn't actually strip it down, i just took it out the way while i was working on the suspension Link to comment Share on other sites More sharing options...
caseys Posted August 6, 2009 Share Posted August 6, 2009 Scott's right, it's just a few hoses to pull off and pull the pump off the reservoir. One think I would make sure you have is the little rubber seal on the pump itself! This is prone to perish so the old one may crumble/break when you take the knackered pump off. Without this rubber seal/o-ring it won't make a perfect fit. Found this out when I had to replace mine... and I bought a pump off a breakers/trader and the seal wasn't on there, I guess because it too had perished Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted April 12, 2011 Share Posted April 12, 2011 (edited) Hey People, sorry to Hi-jack the thread Do the rear and front washers have seperats pumps? My rear washer works but my front dosent, theres no sound coming from the pump neither when i pull the stork... So i assume that i'll need a new pump but if anyone can advise? *EDIT* Sorry, Just found another thread saying its the same pump.... so what could my problem be?? HELP! This is the only thing i now need to sort so it can be MOT'd Cheers D Edited April 12, 2011 by DuaneT.Turbo (see edit history) Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted April 12, 2011 Share Posted April 12, 2011 Sorry again.... i was pulling the stalk and i see theres a button [OOPS][/OOPS] it Works D Link to comment Share on other sites More sharing options...
