Wild question - anyone used the GHC compiler before?
MrRalphMan
Hi all,
I've got a small program that has been written in Haskell and am using the GHC compiler to run it in interactive mode.
Basically it runs in a DOS window, but the issue is that it generates more output then the buffer can hold. Now I'm not sure how I can point the output to a file, to capture all the output.
Anyone got an idea?
Paul.
Ah, I see. I guess there is a way to run it straight from a command line, but then you wouldn't have debugging.
So alternatively, you could set up the redirection at the start of your program. Looking around I found this example, which uses pipes and 'fdToHandle': http://book.realworldhaskell.org/read/systems-programming-in-haskell.html
So maybe something like:
  outfile
  stdouthdl
I'm not sure if there is a function called createFile, or what it's arguments would be, in Haskell, but you can probably guess what I'd expect it to do!
Right, sorted this.. whoopy...
I compiled it using
ghc --make test.hs -o test
This created the .exe file, then I just redirected the output of this with the standard DOS command as above.
Now all I need to do is run the True Crypt cracking program to hopefully find the password to my TC file.
Cheers though.
