Dave Posted July 9, 2009 Share Posted July 9, 2009 my heater matrix is leaking coolant into the footwell only a small amount, i put the heater on monday morning and the screen misted up as soon as the heater got warm so im guessing its the matrix leaking .please put me right are there any rubber water pipes inside the car or do they connect too the matrix from the bulkhead side ??. doesnt leak when the heater is off ? [or not as much] can i run RADWELD through the system good/bad idea??? definately not looking forward to removing the dash to fix it Link to comment Share on other sites More sharing options...
JustGav Posted July 9, 2009 Share Posted July 9, 2009 NO to radweld. You can bypass the matrix with either two copper bungs or a bit of pipe joining it. Do search and you will find plenty of info on this. The pipes run into the bulkhead just near the charcoal cannister. Link to comment Share on other sites More sharing options...
Dave Posted July 9, 2009 Author Share Posted July 9, 2009 (edited) OMG just read through jezz,s how to guide .only took him 3 hours . thanks justgav dont want to do a bypass job can see the pipes bulkhead side just been and looked. btw why is it not good to radweld ?????? if you run it through leave it for a week then flush it and refill ?: Edited July 9, 2009 by Dave (see edit history) Link to comment Share on other sites More sharing options...
JustGav Posted July 9, 2009 Share Posted July 9, 2009 Radweld will end up gunging up other things.... Jezz's guide is good, but if it is your first time doing it, allocate a full day. Link to comment Share on other sites More sharing options...
Dave Posted July 9, 2009 Author Share Posted July 9, 2009 Radweld will end up gunging up other things.... Jezz's guide is good, but if it is your first time doing it, allocate a full day. gonna take my time will use the saxo Link to comment Share on other sites More sharing options...
Jezz Posted July 9, 2009 Share Posted July 9, 2009 If you were'nt in Wales, i'd come and do it for you! Link to comment Share on other sites More sharing options...
Dave Posted July 10, 2009 Author Share Posted July 10, 2009 If you were'nt in Wales, i'd come and do it for you! thanks JEZZ if you wasnt in silverstone i would let you btw jezz how much do you charge for this service might be worth the run up Link to comment Share on other sites More sharing options...
Jezz Posted July 10, 2009 Share Posted July 10, 2009 thanks JEZZ if you wasnt in silverstone i would let you btw jezz how much do you charge for this service might be worth the run up Thinks its around £250, will need to check that though. Link to comment Share on other sites More sharing options...
EdMorris Posted July 10, 2009 Share Posted July 10, 2009 Doing it yourself is not as scary as you might think. I followed Jezz's write up (very good one by the way), and it wasn't that hard. Plus you can sort any dash squeaks/rattles while you're at it and screw everything nice and tight with new bolts/screws afterwards (if you're a little OCD like me). Link to comment Share on other sites More sharing options...
Dave Posted July 11, 2009 Author Share Posted July 11, 2009 Doing it yourself is not as scary as you might think. I followed Jezz's write up (very good one by the way), and it wasn't that hard. Plus you can sort any dash squeaks/rattles while you're at it and screw everything nice and tight with new bolts/screws afterwards (if you're a little OCD like me). jobs like this dont faze me its just a PITA and i have no garage so it will be on the driveway . Link to comment Share on other sites More sharing options...
EdMorris Posted July 11, 2009 Share Posted July 11, 2009 jobs like this dont faze me its just a PITA and i have no garage so it will be on the driveway . Fair enough, having no garage is definately a pain. Link to comment Share on other sites More sharing options...
