25mm Hubcentric Spacers
Scott
Anyone interested in hubcentric wheel spacers? These are not to be confused with the regular tat as i made these myself in work to 0.001" with ever dimension.
They are made from aircraft grade aluminium to the highest standard. I would keep them but i no longer require them due to getting a better offset wheel for my application.
I can do pics etc once they are off the car. I will give them a bit of a clean etc before they go.
The strength of these will be far superior to any other ones on the market due to the way i have made them. The studs have been tapped in and countersunk from the rear meaning that the full head of the bolt is there. The bolts are 8.8 tensile steel and i will also be supplying the shallow mount nuts.
Pics will follow later this week when they are ready to go, any questions please ask. The material, nuts and bolts alone cost just under £50 so i'm looking for offers over that. Inferior versions of these go for well over £100.
