edd_t Posted June 29, 2009 Share Posted June 29, 2009 Have recently developed a metal on metal 'shhhhh shhhhh' noise from drivers side rear wheel. Its not constant until your brake, then you get a constant shhhhhhh noise. So am guessing it probably not bearing, as when the bearing on the other side went the shhhh shhhh noise carried on when braking (if that makes sense) Could it be a warped disk maybe? And whats the best way of diagnosing the problem myself? Cheers, Edd... Link to comment Share on other sites More sharing options...
adnanshah247 Posted June 29, 2009 Share Posted June 29, 2009 maybe its a seized callper, not pulling the pads back away from the disk. Link to comment Share on other sites More sharing options...
pistonbroke Posted June 29, 2009 Share Posted June 29, 2009 Worn pads? Link to comment Share on other sites More sharing options...
edd_t Posted June 30, 2009 Author Share Posted June 30, 2009 guess im gonna have to get the wheel off this weekend. how do i check if the caliper is seized, is it easy to see? Link to comment Share on other sites More sharing options...
