Supra_Al Posted October 11, 2002 Share Posted October 11, 2002 My 1993 jap spec, has had the speedo changed to MPH,but my odometer still reads in Kilometers which is rather annoying.Can i get this changed to show good old British Miles??? Al. Link to comment Share on other sites More sharing options...
Piran Posted October 11, 2002 Share Posted October 11, 2002 if you look at http://www.mkivsupra.net under the technical section you will see a link to : Pete Betts Speedo and Odometer conversion Link to comment Share on other sites More sharing options...
Supra_Al Posted October 11, 2002 Author Share Posted October 11, 2002 Thanks for your help.......but that looks a bit tricky for me! How much does it cost to get it done? Is there anyone local (ish) to me to do it.I'm in Swindon.Al. Link to comment Share on other sites More sharing options...
Bradb Posted October 11, 2002 Share Posted October 11, 2002 Mines the same Al.. I never got around to changing it either Link to comment Share on other sites More sharing options...
Supra_Al Posted October 11, 2002 Author Share Posted October 11, 2002 Originally posted by Bradb Mines the same Al.. I never got around to changing it either Me thinks we need to get it sorted Brad! Al. Link to comment Share on other sites More sharing options...
Rob_B Posted October 11, 2002 Share Posted October 11, 2002 Mines the same as that too.. My speedo also only goes up to 120MPH. If I want to get the 180 speedo do I have to buy a complete new unit or just change the face and get some kind of converter ? Ta, Rob. Link to comment Share on other sites More sharing options...
Supra_Al Posted October 11, 2002 Author Share Posted October 11, 2002 My speedo goes up to 180MPH....but the digital odometer is still in Kilometers. Al. Link to comment Share on other sites More sharing options...
Alex Posted October 12, 2002 Share Posted October 12, 2002 Rob, get pete's DSC to change KMH tp MPH (just stick an MPH label on it if your easily confused!!) Al, you can do this mode (think you cut a wire on the odo) BUT condider that all your previous documantation is probably in KM's and so a change might put off prospective buyers in the future...not saying you'll sell it soon but every car has a life span usually less than its owners... Link to comment Share on other sites More sharing options...
Rob Posted October 12, 2002 Share Posted October 12, 2002 No that won't work, Rob's sounds like mine, the speedo face has been changed to read in MPH, max 120. He needs a new (original) speedo face plus the Betts de-limiter. I got mine from Supraman at Meopham, but it took a while. Combine it with a switch to indiglo dials:) Link to comment Share on other sites More sharing options...
Digsy Posted October 14, 2002 Share Posted October 14, 2002 My advice (all in my most humble opinion) would be to sort the speedo but leave the odo be. Get a stock dial face (or look under yours to see if the stock one is still there), get a Pete Bett's box of tricks and feed the modded signal to the speedo only at first. Then you can also splice into the feeds to the other speed signal dependant systems on the car as required. If you mod the odo first, then ALL systems on the car will get the modded signal, whether they want it or not. Also, leaving the odo reading in km will sound a lot less "dodgy" when you come to sell the car, because the new owner wont have to do any hard sums to work out the true mileage. Link to comment Share on other sites More sharing options...
randy Posted October 14, 2002 Share Posted October 14, 2002 TRD 320k speedo anyone? Link to comment Share on other sites More sharing options...
Rob Posted October 14, 2002 Share Posted October 14, 2002 or mod the odo to read in miles but don't tell anyone, and claim its still Km. Did I say that, surely not? Link to comment Share on other sites More sharing options...
