uk-rich Posted June 10, 2009 Share Posted June 10, 2009 i'm selling my suspension due to buying a new set from a member on here, these really are in very very good condition, from new i protected them with "gold grease" on all the threads and locking rings, there is no corrosion at all, and eveything is free, i have wiped this off so you can see how good they are i will supply the buyer with some grease so it can be re-applied to protect them i recieved the dampers on the 11/11/07 so they are less than 2 years old, and i hardly ever use the car, and then its dry miles only, they have seen less than 3 housand miles they have adjustable spring platforms and adjustable shockbody lenght, as well as adjustable dampning (rom the top using the supplied tool) the adjustments allow them to be setup however you like it, from soft to firm, ride height high or low this is the official blurb, Featuring the latest technology from HKS and the suspension world, these are a great coilover for the street and track. These coilovers feature: • Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases • Strengthened rubber upper mounts – Enhanced durability and better handling than stock equipment, while giving you the ultimate in comfort • Monotube design – The Best • Shock-body length adjustable – You can adjust the height of your Supra without changing your spring rate, a feature found on very few coilovers • 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency • Stainless lock nut & ride height adjuster – feature anti-rust and corrosion characteristics for enhanced durability • 30-way adjustable dampening per corner • Hard chrome-plated cylinder shaft • Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions • Pillowball upper mounts optional on certain applications • Dustboots included to keep them in their best condition Their spring rate is: Front: 12kg/mm / 672 lbs/in Rear: 7kg/mm / 392 lbs/in as i said these are really in as new condition, if you require any close up shots or more info just ask i will send them via courrier at my own cost, i'm looking for £700 for these Link to comment Share on other sites More sharing options...
JohnH Posted June 10, 2009 Share Posted June 10, 2009 pm'd Link to comment Share on other sites More sharing options...
uk-rich Posted June 10, 2009 Author Share Posted June 10, 2009 sold pending payment Link to comment Share on other sites More sharing options...
JohnH Posted June 10, 2009 Share Posted June 10, 2009 crap Link to comment Share on other sites More sharing options...
little num Posted June 10, 2009 Share Posted June 10, 2009 hey rich they look nice, shame i didnt see this before the new owner did. Link to comment Share on other sites More sharing options...
ace67 Posted June 10, 2009 Share Posted June 10, 2009 crap nr 2 ...i wanted these [sAD][/sAD] Link to comment Share on other sites More sharing options...
