GeordieSteve Posted April 11, 2005 Share Posted April 11, 2005 Just took the Sup for a quick run around the block before it's MOT tomorrow. Back in November I had the following mods: Veilside cat back Double de-cat with restrictor ring Apexi Power air filter NGK BKR7E's Boost controller TRL FCD Now when I put my boot down, now and again the warning light would come on the dash for a second then go out. Strange I thought... then I blew a turbo! I thought it must have been a warning that my turbos were on the way out so left it as that. Now I've added: Hybrids Walbro fuel pump FMIC S-AFC II (Injectors etc. being put in tomorrow and I've turned the boost controller off) Now I'm STILL getting that light coming on Anyone got any ideas? It's all away to be mapped at the same time so no doubt the guy will come up with a solution but I'm just a bit nervous what it could be Link to comment Share on other sites More sharing options...
Getrag Posted April 11, 2005 Share Posted April 11, 2005 Brake fluid level. Has to be pretty exact ive heard. So when you boot it, the fluid sloshes about and goes below the min' level. Link to comment Share on other sites More sharing options...
GeordieSteve Posted April 11, 2005 Author Share Posted April 11, 2005 And that makes the warning light come on? Whey ya bugger! Cheers Link to comment Share on other sites More sharing options...
Elliot Posted April 11, 2005 Share Posted April 11, 2005 Brake fluid level. Has to be pretty exact ive heard. So when you boot it, the fluid sloshes about and goes below the min' level. Exactly what I thought. Loads of people have posted up about this & pretty much every single one has been low brake fluid. Shame there couldn't be different lights like some of the newer cars. Link to comment Share on other sites More sharing options...
