Wiring a Blitz Power meter
Carl
  • 1 month later...
Carl don't know if you've fitted your Blitz Power Meter by now mate, but yes it is the same ecu pink wire that a (BCC/fuel cut device) connects to.
I recently fitted my Blitz Power Meter using the same pink ecu wire and it is all working perfect :)
Hope this helps mate??
Steve
Hold on, something isn't right here.
The fuel cut doesn't connect into the speed sensor at all, it connects into the MAP sensor.
The speed wire wouldn't connect to this, as I said in a previous post, according to the manual it should be connected to the input of your speed converter and not after it.
So would the correct wire be the red/black wire from the speed sensor to the speedo or odo unit??
I don't have a speed converter fitted as my car has a UK spec speedo fitted along with a UK spec modded odo unit.cheers
Have you got the pinouts for the blitz unit, I can't seem to find an installation manual other than the operation manual.
From memory the pink wire (pin 2) on the Thor diagram is the same pink wire that my Greddy BCC was connected to.So i'm a bit baffled now!!
I will double check tommorrow to confirm if this is the case.
I previously read a thread on here that stated that there is a red/black input wire that goes from the speed sensor to the odo + speedo unit, and then a pink output speed sensor wire comes from the odo + speedo unit and goes to the rest of the car??
I think you are on the money with the pink wire for the speed sensor.
Have a look here, http://www.mkiv.com/techarticles/bcc/bcc_install/bcc_intro.htm.
The only thing that crosses my mind, is perhaps you have a combined fuel/cut speedo convertor unit??
After i fitted the power meter i compared the speed reading it was giving to my cars speedo and it was within 2mph accurate, and this was before i calibrated it.
It's hard to tell if the hp reading is accurate but it's currently displaying approx 350 bhp at 0.7 bar, with my current single turbo setup.
