Guest adam b Posted April 21, 2009 Share Posted April 21, 2009 my nur spec is touching the ground at times when i drive . should they be so low or have i got a duff one. any info would be gratefully received. atb adam b:D Link to comment Share on other sites More sharing options...
sypher_44 Posted April 21, 2009 Share Posted April 21, 2009 is the car lowered? Link to comment Share on other sites More sharing options...
SimonT Posted April 21, 2009 Share Posted April 21, 2009 Mine sits extremely low but only scrapes over bumps etc! Are you missing part of a hangar for it?? Link to comment Share on other sites More sharing options...
magictorch Posted April 21, 2009 Share Posted April 21, 2009 They all sit pretty low;) Link to comment Share on other sites More sharing options...
TopgunTT Posted April 21, 2009 Share Posted April 21, 2009 They shouldn't touch the ground, Mine occasionally scrapes a speed hump but thats about it. How long has it been doing it? Since it was fitted? Link to comment Share on other sites More sharing options...
Guest adam b Posted April 21, 2009 Share Posted April 21, 2009 its done it ever since fitting,,its fitted correctly iv had a look under the car. it scrapes over speed bumps and at speed as the road dips as the suspension works... would some EIBACK PRO,S do the trick?? Link to comment Share on other sites More sharing options...
j80leo Posted April 21, 2009 Share Posted April 21, 2009 its done it ever since fitting,,its fitted correctly iv had a look under the car. it scrapes over speed bumps and at speed as the road dips as the suspension works... would some EIBACK PRO,S do the trick?? Any excuse to buy some supension lol:p Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted April 21, 2009 Share Posted April 21, 2009 mine hangs low as it bends for the rear frame but it never touches the ground, even on speed bumps. I would put it on a ramp and check it for proper installation. Link to comment Share on other sites More sharing options...
Steviekid Posted April 21, 2009 Share Posted April 21, 2009 it scrapes over speed bumps and at speed as the road dips as the suspension works... Mine does that too Link to comment Share on other sites More sharing options...
Guest adam b Posted April 21, 2009 Share Posted April 21, 2009 thanks lads i will put it on the ramp again, and have a second look. just to make sure ....meny thanks adam b Link to comment Share on other sites More sharing options...
