pjavon Posted April 21, 2009 Share Posted April 21, 2009 Am i right in thinking the rear brake pads are square-ish on uk spec and oblong on j-spec. Need to replace my rears, 94 j-spec N/A, and my local Mr T is not that good. I have seen these on Ebay but after doing a search on here it seems they won't be the square-ish type on mine? http://cgi.ebay.co.uk/BP827-REAR-BRAKE-PADS-TOYOTA-CELICA-SUPRA_W0QQitemZ230305939117QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item230305939117&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 Any help is really appreciated Link to comment Share on other sites More sharing options...
hoff Posted April 21, 2009 Share Posted April 21, 2009 Step away from ebay;) You're best off going to Steve manley or Paul Whiffin for stock pads. Honest. If you want uprated pads, I'd go for Chris Wilson fast road pads, but they are not cheap. But definately OEM are best if you simpily want to replace worn pads:) Link to comment Share on other sites More sharing options...
hoff Posted April 21, 2009 Share Posted April 21, 2009 Part number - rear pads-#04466-30030 [NA] taken from this usefull list. I assume U.S. part numbers are the same - http://www.mkivsupra.net/vbb/showthread.php?t=126735&highlight=brake+part+numbers Link to comment Share on other sites More sharing options...
AdzC Posted April 21, 2009 Share Posted April 21, 2009 I got my replacement J-spec pads from my local motor factors. They are the same as the Lexus GS300 if that helps you out. Link to comment Share on other sites More sharing options...
pjavon Posted April 21, 2009 Author Share Posted April 21, 2009 Thanks for the help. Took your advice Adam and just ordered Toyota ones, £38 for the set and should be in on Thursday. Link to comment Share on other sites More sharing options...
