Vagnum Posted April 11, 2009 Share Posted April 11, 2009 I could of kick myself yesterday, i was replacing the valve stem seals and broke the plug connection bit off my iacv vsv [sHOCK][/sHOCK]. If i went TTC http://www.internetwork.org.uk/ttc/ttc.htm, what would happen if the plug is disconnected from the iacv vsv i'm guessing the ecu will go into limp mode right? can the connector be bridged with a resistor? or will it be ok just off. Link to comment Share on other sites More sharing options...
