themodifiedkid Posted March 29, 2009 Share Posted March 29, 2009 I don't know if this is normal but i noticed on the outside of the door windows the strip that runs along the bottom of the window doesn't sit flush/ snug against the window. Is there supposed to be a small gap there? Its just otherwise there is nothing to stop the water running straight down the window and inside the door itself. Apologies if this is a silly question as Ive only really just noticed this in the last couple of days. Cheers people Link to comment Share on other sites More sharing options...
AlanM Posted March 29, 2009 Share Posted March 29, 2009 nope, there should not be a gap at all Link to comment Share on other sites More sharing options...
themodifiedkid Posted March 29, 2009 Author Share Posted March 29, 2009 oh thought as much. Does any body know where I can get replacements from in a hurry and what sort of money they cost? Or is it something that i could just simply adjust? nope, there should not be a gap at all Link to comment Share on other sites More sharing options...
AlanM Posted March 29, 2009 Share Posted March 29, 2009 Steve Manley if you are in a hurry 01865291333 (Inchcape Toyota, gives discount to club members) If you can wait a few weeks Nic (Import Pimp, much cheaper) Link to comment Share on other sites More sharing options...
themodifiedkid Posted March 29, 2009 Author Share Posted March 29, 2009 Steve Manley if you are in a hurry 01865291333 (Inchcape Toyota, gives discount to club members) If you can wait a few weeks Nic (Import Pimp, much cheaper) Ok nice one cheers for the info Alan , much appreciated Link to comment Share on other sites More sharing options...
AlanM Posted March 29, 2009 Share Posted March 29, 2009 Just changed all door seals and window seals on mine when it was re-sprayed but I got all the bits together so not sure what the costs of thse particular ones Link to comment Share on other sites More sharing options...
marbleapple Posted March 29, 2009 Share Posted March 29, 2009 Just to confirm.... The rubber over the top of the door.... that should be flush with the roof bit? Link to comment Share on other sites More sharing options...
Rich8v Posted March 29, 2009 Share Posted March 29, 2009 Just to confirm.... The rubber over the top of the door.... that should be flush with the roof bit? Mine dosn't sit flush, and ive never thought it is right. I keep forgetting at meets to check other cars. Link to comment Share on other sites More sharing options...
Jason Posted March 29, 2009 Share Posted March 29, 2009 I had the same trouble on mine after it came back from paint. There is a pop rivet each end of the seal. All I had to do was put new rivets in as the old ones had been drilled out from a previous paint job. The seal now sits vert tight to the window. Jason Link to comment Share on other sites More sharing options...
themodifiedkid Posted March 30, 2009 Author Share Posted March 30, 2009 I had the same trouble on mine after it came back from paint. There is a pop rivet each end of the seal. All I had to do was put new rivets in as the old ones had been drilled out from a previous paint job. The seal now sits vert tight to the window. Jason Cheers for all the replies, i will check this out tomorrow and see if this is what has happened coz I did have a respray 2 weeks ago Link to comment Share on other sites More sharing options...
themodifiedkid Posted March 30, 2009 Author Share Posted March 30, 2009 Just to confirm.... The rubber over the top of the door.... that should be flush with the roof bit? No mate its the section that sits along the bottom of the drop glass Link to comment Share on other sites More sharing options...
bodilx6 Posted March 31, 2009 Share Posted March 31, 2009 (edited) I just got quoted just about £100 per rubber strip from toyota. I'll guess about 20% could be taken off that with a discount. Two for each side. For the hardtop Edited April 1, 2009 by bodilx6 (see edit history) Link to comment Share on other sites More sharing options...
themodifiedkid Posted March 31, 2009 Author Share Posted March 31, 2009 I just got quoted just about £100 per rubber strip from toyota. I'll guess about 20% could be taken off that with a discount. Two for each side. Link to comment Share on other sites More sharing options...
