JohnK Posted April 1, 2005 Share Posted April 1, 2005 Im running v1.39 firmware in the emanage, and v1.11 support tool software. Im told that if I enter the parameter settings with 1.11 the e-manage will crash and need the firmware re-writing. I have got the updates to 1.13 from 2 seperate sources, but after I install them the s/w will not commincate with the emanage. It just opens the comunication box and sits there. Matt H used 1.13 on his laptop to talk to it. Ive tried 2 seperate laptops and winxp and ME. Any ideas why I cant run v1.13. Link to comment Share on other sites More sharing options...
AeroMatt Posted April 1, 2005 Share Posted April 1, 2005 I'm having exactly the same problem, however I'm not sure what benefits 1.13 gives over 1.11 so I'm leaving mine as is for now. You may be able to find an answer at; http://www.emanageusers.com/ its a very useful forum for emanage information. They are in the process of working out how to update the firmware on the blue emanage to the gold version. Link to comment Share on other sites More sharing options...
SimonB Posted April 1, 2005 Share Posted April 1, 2005 I've just tried V1.13, works fine for me with 1.39 firmware. I was using V1.11 with the same firmware - I don't think you'll have any problems with that. I downloaded the upgrade from Mohd's site (http://www.mohdparts.com) - you unzip it and copy two files over your 1.11 software. Link to comment Share on other sites More sharing options...
dude Posted April 1, 2005 Share Posted April 1, 2005 Are you using a serial port or a serial/USB adaptor Dude Link to comment Share on other sites More sharing options...
heckler Posted April 1, 2005 Share Posted April 1, 2005 i have 1.13 firmware and 1.39 software - i used a modified usb cable which has a built in serial convertor - works no probs. Link to comment Share on other sites More sharing options...
SimonB Posted April 1, 2005 Share Posted April 1, 2005 i have 1.13 firmware and 1.39 software - i used a modified usb cable which has a built in serial convertor - works no probs. Yep, me too, I have the clone USB cable from here:- http://chips.car-hacker.com/viewtopic.php?t=470 Link to comment Share on other sites More sharing options...
heckler Posted April 1, 2005 Share Posted April 1, 2005 Yep, me too, I have the clone USB cable from here:- http://chips.car-hacker.com/viewtopic.php?t=470 thats the one! Link to comment Share on other sites More sharing options...
JohnK Posted April 2, 2005 Author Share Posted April 2, 2005 One laptop has a built in serial port the other a PC card serial adaptor. Both talk happily on version 1.11. Im using Matt H's cable that he used with 1.13 so I dont think its the cable. Link to comment Share on other sites More sharing options...
JohnK Posted April 3, 2005 Author Share Posted April 3, 2005 bump Link to comment Share on other sites More sharing options...
JohnK Posted May 7, 2005 Author Share Posted May 7, 2005 I have found a solution, it works under win2K. 1.13 wont work under ME and for some unknown reason (perhaps the xp partition being old and full of crap) it wouldnt run under XP either. Fresh install of win2K and 1.11 and more importantly 1.13 works, both with a firmware of 1.39. Link to comment Share on other sites More sharing options...
JohnK Posted May 8, 2005 Author Share Posted May 8, 2005 well that was short lived it did work under 2k, nothing at all has changed on the PC yet now it will only comunicate with v1.11 again. To say im now annoyed is an understatment. Link to comment Share on other sites More sharing options...
