georigg Posted March 2, 2009 Share Posted March 2, 2009 I've had a search for this but have not found any info, perhaps someone on the board may have a solution. The printed circuit board where the oil warning, oil level, ABS indicators are located appears to be a constant source of problems through not lighting when the ignition is switched on. From my own, it appears that there is an intermittant fault in the PCB tracking that results in an open circuit at times. Has anyone found a cure for this and what recommendations are there to fix this? Much obliged for any info. Rgds George Link to comment Share on other sites More sharing options...
Animal Posted March 2, 2009 Share Posted March 2, 2009 Yes, it's a common fault 'dry joints' you just need to re-solder the board and it'll be fine. Link to comment Share on other sites More sharing options...
georigg Posted March 2, 2009 Author Share Posted March 2, 2009 Hi Animal, Is it all of the joints or only certain ones????? between the two little PCBs? Cheers George Link to comment Share on other sites More sharing options...
heckler Posted March 2, 2009 Share Posted March 2, 2009 Hi Animal, Is it all of the joints or only certain ones????? between the two little PCBs? Cheers George just do them all - only take a few seconds... it usually the joints on the PCB with the plug on it Link to comment Share on other sites More sharing options...
georigg Posted March 2, 2009 Author Share Posted March 2, 2009 Hi Heckler/Animal, Many thanks for the info, best regards George Link to comment Share on other sites More sharing options...
