alaing Posted February 18, 2009 Author Share Posted February 18, 2009 blocked injector mayb? It was run on low fuel so may have picked up crap from the bottom of the tank and got through to the injector il have to check, it not an easy job though to take the injectors out. Link to comment Share on other sites More sharing options...
tonyhawk Posted February 18, 2009 Share Posted February 18, 2009 It's a bit of a pain, but shouldn't take more than about 1.5 hours or so. It might be worth checking the idle valve at the back of the plenum chamber? I'm grasping at straws a bit there though... I might be a blocked or split vacuum pipe, which might explain the poor pickup? Link to comment Share on other sites More sharing options...
alaing Posted February 18, 2009 Author Share Posted February 18, 2009 Yeh ive taken the idle valve out and cleaned it up, no luck there . Ill have to take the injectors out to clean and test them see if that helps. really appreciate your time and input tony. Link to comment Share on other sites More sharing options...
hadyn Posted February 18, 2009 Share Posted February 18, 2009 Its tottally standard. Its got a set of brand new NGK BKR6EIX s in it. Do you think i should try a smaller gap on them? Set the gaps to the settings given in the FAQ section of this forum mate, you should have no problems then. Link to comment Share on other sites More sharing options...
alaing Posted February 18, 2009 Author Share Posted February 18, 2009 its says not to gap them. It should be 1.1 ill check them. Link to comment Share on other sites More sharing options...
tonyhawk Posted February 18, 2009 Share Posted February 18, 2009 Happy to help mate. It's worth checking the gaps, but I'd be surprised if they affected it at tickover? If you want to try different injectors, give me a shout. Link to comment Share on other sites More sharing options...
alaing Posted February 18, 2009 Author Share Posted February 18, 2009 Thanks ill get back to you. If you have any other ideas please post them. Link to comment Share on other sites More sharing options...
