Sharpie Posted September 9, 2002 Share Posted September 9, 2002 Hi, I have my car going to get the alignment done tomorrow at my local dealer and will provide them with Lance's recommendation but, I see that they are all in degrees apart from the last one - Rear Toe IN 1.0mm. So If: 0.080 is 2mm 0.120 is 3mm What is 1.0mm in degrees ? Or will Toyota be OK with this measurement ? Thanks *************************************************** From MKIV.com 1. What is a Good Street/Lance W. Alignment? Front: Camber - 1.0 Caster + 5.0 Toe 0.00 Rear: Camber -1.5 Toe IN 1.0 mm The Front and Rear Toe are critical to tire wear, even small deviations from spec may cause unusual wear patterns or excessive wear. Link to comment Share on other sites More sharing options...
Alex Posted September 9, 2002 Share Posted September 9, 2002 ummm 0.40 or was it a trick question? Link to comment Share on other sites More sharing options...
Sharpie Posted September 9, 2002 Author Share Posted September 9, 2002 Originally posted by Alex Holdroyd ummm 0.40 or was it a trick question? No - just wanted to double check. Thanks - It's been a long day. Pete Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 9, 2002 Share Posted September 9, 2002 Originally posted by Alex Holdroyd ummm 0.40 or was it a trick question? LOL:D Sorry Peter, no offence meant! Link to comment Share on other sites More sharing options...
matt Posted September 9, 2002 Share Posted September 9, 2002 The camber and castor values are always in degrees .... Toe in can be expressed as an angle or as a measurement ..... they will be fine understanding it Link to comment Share on other sites More sharing options...
Sharpie Posted September 9, 2002 Author Share Posted September 9, 2002 Cheers man. Link to comment Share on other sites More sharing options...
Need4Speed Posted September 12, 2002 Share Posted September 12, 2002 I'm a little surprised to see parallel at the front. I would have expected vague straight line stability. What size are your tyres? Link to comment Share on other sites More sharing options...
