Clutch Resevoir Oil/Fluid
Alex
I've noticed that on my manual transmission my clutch resevoir oil/fluid level has dropped below the min line :eek:
What oil/fluid should I top it up with?
To top it up do I just pull the cap off the top?
Does it get "used" or am I likely to have a leak...its about an inch down (not alot of fluid in a thin pipe but still worrying)
TIA
Alex "Rolling from one disaster to another" Holdroyd
Check for leaks around the master cylinder around the bulkhead & the slave - on the bellhousing ...that's if it's like most other cars - my Supra's an auto . Otherwise just top-up with brake fluid & keep an eye on it .... no it doesn't get used ....afaik .
