Alex Posted September 5, 2002 Share Posted September 5, 2002 I've noticed that on my manual transmission my clutch resevoir oil/fluid level has dropped below the min line What oil/fluid should I top it up with? To top it up do I just pull the cap off the top? Does it get "used" or am I likely to have a leak...its about an inch down (not alot of fluid in a thin pipe but still worrying) TIA Alex "Rolling from one disaster to another" Holdroyd Link to comment Share on other sites More sharing options...
Myles Posted September 5, 2002 Share Posted September 5, 2002 Check for leaks around the master cylinder around the bulkhead & the slave - on the bellhousing ...that's if it's like most other cars - my Supra's an auto . Otherwise just top-up with brake fluid & keep an eye on it .... no it doesn't get used ....afaik . Link to comment Share on other sites More sharing options...
Adam W Posted September 5, 2002 Share Posted September 5, 2002 The Mk3 is well known for leaking around the drivers footwell - feel around the actual mechanism of the clutch pedal to see if it's at all wet. Just use el cheapio brake fluid in it, DOT3 or whatever. Link to comment Share on other sites More sharing options...
