max temp of an auto box?
Spoony
hi
a friend of mine has a BL build auto box.
temps are going up to 130 celsius on the autobahn with oilcooler.
how much is the maximum before damage?
thanks
eddie
i would say you are pretty much there at that temp, i did quite a bit of research on the auto box temps and 130 C is getting toward the max, the fluid will be degrading at that temp as well, personally i run 110 C as an absolute max and since fitting an even bigger cooler have never seen anything over that and thats with a high stall, i now run 2 coolers one fluidyne (which are pretty crap TBH) and one good size mocal cooler, your mate needs either another cooler or a bigger one, to go to all the trouble and expense of a built box and then cook it sounds crazy
