supra_si Posted October 21, 2008 Share Posted October 21, 2008 Fitted my fmic yesterday but now when my turbos spool up theres like an echo / whirrling noise coming from the left of the engine. is this usual with metal piping? Link to comment Share on other sites More sharing options...
supra_si Posted October 21, 2008 Author Share Posted October 21, 2008 Can boost leak be audible?? Link to comment Share on other sites More sharing options...
zap Posted October 21, 2008 Share Posted October 21, 2008 I get this noise from the offside, it is not there all of the time, seems worse when the engine is cold. (I have standard smic). I put thread on here but no one seemed to know. Link to comment Share on other sites More sharing options...
SilverSoop Posted October 21, 2008 Share Posted October 21, 2008 Can boost leak be audible?? I can tell you that I had exactly the same damn thing. Does it sound like a kind of 'howling' noise?? On mine, it turned out to be that one of the Jubilie clips on the left side of the FMIC was a little loose and needed tightening. After this though, the boost leak had gone... And yes, that type of boost leak can be audible. Mine was. Link to comment Share on other sites More sharing options...
supra_si Posted October 22, 2008 Author Share Posted October 22, 2008 and did this stop the howling?? il have to further investigate as im sure they where on damn tight. Thanks for the help I t does sound like second sucking sound, The car still boosts ok but the ssqv is a little quieter than normal. I was wondering if it had anything to do with now having metal pipes, thought the turbo spool might have been echoing through them Link to comment Share on other sites More sharing options...
SilverSoop Posted October 22, 2008 Share Posted October 22, 2008 and did this stop the howling?? il have to further investigate as im sure they where on damn tight. Thanks for the help I t does sound like second sucking sound, The car still boosts ok but the ssqv is a little quieter than normal. I was wondering if it had anything to do with now having metal pipes, thought the turbo spool might have been echoing through them Yep stopped the howling straight away... It started at 0.4 bar and got worse through to 0.6 bar... I would check that your FMIC is on correctly, check all the hoses and the Jubilie clips. But from what you are experiencing, I would say definetely a Jubilie clip needs a tweak of your screwdriver... Link to comment Share on other sites More sharing options...
supra_si Posted October 23, 2008 Author Share Posted October 23, 2008 thanks mate il have a look later on. only got my stock jack with me as im away at the moment but got a spanner and ratchet set Link to comment Share on other sites More sharing options...
SilverSoop Posted October 23, 2008 Share Posted October 23, 2008 thanks mate il have a look later on. only got my stock jack with me as im away at the moment but got a spanner and ratchet set No worries Si... Link to comment Share on other sites More sharing options...
supra_si Posted October 23, 2008 Author Share Posted October 23, 2008 All sorted, a cpl of jubilee clips where loser than when i initially put them on, its all quiet and boosting properly, Thanks for your help buddy Link to comment Share on other sites More sharing options...
