Gear Ratio's
npotts
Hi Guys
One thing about being a Motorbike owner, is that I have the option of changing the sprockets on my bike to improve acceleration and cut something off the top end. After all, when am I going to get the chance to do 160+mph?!
Being pretty un-knowledgeable with cars, I was wondering if anyone could give me some technical advice...
Is it possible to amend the equivalent of a motorbike sprocket on a Supra? I very rarely do over 100mph, and was wondering about changing the gearing (if thats what it is) to improve acceleration and lose some of the top end.
Is this something that can be done? Has anyone on here tried it on a NA or a TT for that matter?
Cheers in advance for any advice
Nick
Probably the easiest way to do what you are after is to change the final drive ratio by swapping the diff. There are one or two options available off the shelf from the different models. No idea what they are but someone on here might do.
HTH.
hmm.... sounds like its not a straight forward change then!
I would have thought it would be quite easy - goes to show my limited knowledge on cars....
Cheers for the help though guys. I doubt I will be sticking any 14" wheels on it though ;-)
Nick
Guest Terry S
I have raised the gearing before.
If your car is manual, try an auto diff, if it is auto, you are stuffed if you want lower gearing ;)
Hi Guys
Nick
Cool - I'd always been under the impression the top speed was lowered....I'd prefer it not to be :) Infact I'd like it raised ;) I tried to find 7th yesterday lol
How does the TRD diff sound? Is it obvious it's not stock? :hijack:
